Log4OM 2.13.0.0 Released
Release note – Version 2.13.0.0
- [NEW] Added export to excel button on grids
- [NEW] Introduced caching for external sources and callsign statistics
- [NEW] Added automatic cluster disconnection when counterpart become unresponsive
- Updated Bonair Island flag
- Hamlib rigs are now alphabetically sorted by manufacturer-model
- Added frequency on email alerts
- Spots can now be sent to localhost if log4om local relay server is offline or uses a different port than the targeted one
- [FIX] Removed <BR> from email alerts and switched to plain text
- [FIX] Fixed an issue that prevented alert email on some circumstances
- [FIX] Fixed an issue that in some cases used the wrong state from external sources when the callsign is decorated with a prefix
- [FIX] Fixed label print label reporting user was not exchanging QSL with correct behaviour
- [FIX] ADIF import counter is now showing the correct amount of QSO imported
- [FIX] Winkeyer QSO references is now properly filled with data
- [FIX] Fixed winkeyer macro issue that prevented some strings to be sent correctly (first character sent issue)
- [FIX] Fixed Hamlib MODE swap issue and other minor things
- [FIX] Included a new Hamlib version with many fixes on specific rig drivers that should fix the “VFO SWAP” issue. More info and specific reports can be addressed to Hamlib software team.
