Log4OM 2.7.0.0 Released
Release note – Version 2.7.0.0
- [NEW] label “SAT MODE” now show the satellite name if selected
- [NEW] Added Band map in main UI (with HIDE button on bottom right)
- [NEW] SPOT SEND screen will now allow you to recover data from previously saved QSO (current session only)
- [NEW] Added more automated massive QSO update capabilities in QSO Management screen
- [NEW] Added massive award confirmation status functions on Award Statistics page
- [NEW] Award export now has more options and support WWFF and POTA ADIF output with SIG/MY_SIG/SIGINFO/MY_SIGINFO output
- [NEW] Added option to avoid label printing on LAST ROW of the sheet. This will enable usage of NON BORDERLESS printers. New parameter is in the LABEL DEFINITION
- [NEW] Added Color support on labels. New parameter is in the LABEL DEFINITION
- Send SEND SPOT button relocated near operator name in main UI
- Award references can now be searched by ALL fields in the reference itself, not only reference code.
- Renamed AWARD STATISTICS into AWARD STATUS
- Hamlib RIG_PASSBAND_NOCHANGE implemented. That should fix the narrow filter issue in Hamlib on mode change, on radio that supports this command
- UPDATED voacap statistic engine
- Added SEND SPOT capabilities to Contest and winkeyer screen
- Band map scroll and spot placement optimizations
- Band map can now follow radio band
- Award statistics columns made resizable
- Antenna identification routine optimized
- Cluster detected “SPOT MODE” overrides emission type from bandplan value to real mode emission type
- Maximum number of open external Band Map reduced to 1
- [FIX] Band order in station radio/antenna configuration properly sorted on ADD list
- [FIX] EQsl/LOTW download date no more moved to -1 years from today when multiple download requests are performed in the same day
- [FIX] PSE QSL * now marks correctly QSO that require QSL confirmation in label print
- [FIX] Fixed issue in QSO Edit for references not selectable even if set invalid after QSO date (id #299)
- [FIX] Fixed twice MY_STATE adif tag export.
